Old 01-02-2011, 05:00 AM
Default Re: Stahl Liebherr LR632
Originally Posted by Claus View Post
Is the gun for smart a$$ truck drivers or non-backer upers or???
It's for keeping the larger Cats and Komatsus away
Xllnt details Emil.
I suppose with your abilities to mix hyd functions with pump rotation that using this 7.2v Tamiya motor works quite well & never runs too fast?
Everybody in your norwegian group run Servonaut esc's? Is it the Servonaut electronics or 2.4 radio systems or both that eliminate glitch all together?
I need to do some upgrading with my electronic systems in my constr equip.
I guess it prevents glitching. In addition it's so much easier with 2.4GHz at our meetings; no need to worry about frequencies I've seen guys running on the same frequency, and it's not pretty... I guess the reason most are running Servonaut is because it's very good for trucks and constructions machines.
My pumpmotor is limited to about 50%. It's only running when I'm using the lift- or tipfuctions. This way I save alot of power and increase the lifetime of the system. I'm using a 5000mAh 11,1V LiPo battry btw. The radio is a Futaba 10C.
