Old 11-06-2016, 12:56 PM
tracksntreadslou's Avatar
Default Re: Logging & Construction Equipment
Thanks Rob It was good to have a visit with you and greg yesterday ..too bad we forgot to take videos lol..you and Greg got the hang of the sticks pretty quick too..Im sure you are going to be running that thing too in the spring while I push with the D10..
Thanks RW ..It would be nice to be able to have the pump off and be able to mix but with the steering the way it is when pump isn't running the force make the machine wander ....I plan on switching to a better radio the the turnigy ..then run pump between 10 - 25 % and mix as needed ...In the vid I was running maybe 30% and that gave me plenty of hydraulic power...I did do some adjustment with the endpoint and the exponential and that really helped with the steering ...Apron is still a little fast and maybe if i swap out the 4mm hoses to 2.5 mm hoses it will make a difference ..
It is good to see bucket is back up so pics coming soon
