#201
Re: 1/16 Bucyrus-Monighan Walking Dragline
Nice work and nice shop
Jeff |
#202
Looks great!
Kerst |
#203
Henry, Look in my 1:1 topic but that's my kids toy I built him back in 97' It's just a little Struck Mini Dozer I modified to resemble a Cat D4C about 1/2 scale I added a hydraulic blade also.
Pugs, That's only about 1/4 of my shop, there's more back in the darkness. We have about 12,000 sq.ft. |
#204
I got a few pieces cut this weekend on the second or middle 30-3/4'' (41') boom section. I had to do some serious filing and sanding to remove the machine marks from the Tee chord sections too.
I could have gotten more done but had the urge to operate the machine with the temporary boom on for about 2+hrs Some tubes cut for both sides |
#205
Looks like you are making some progress steve-are you pleased with the way the model works with the boom section on? Is it strong?
#206
I would really like to see this model in person one day. Its gonna be an awsome model.
#207
I can't try the first section yet. If anything I'm going to just wire tie it under the temporary boom for looks and to keep fingers from touching it while at the show. But to answer your question Tom, It is very strong so far, much stronger than the temporary one that's just tacked together 1/8''x1/2'' flat bar.Also the safety lines add needed strength to keep it from buckling. I am almost finished milling angles and notching the tubes on the second section. After that is done I have to work on those dreaded splice plates again that took so long on the first section.
#208
More pieces this week. I have 66 done but still need 39 more for this section of boom.
Drilling the chord ends 224 holes total 0-80 to tap.on these A nightmare of angles |
#209
very cool!
#210
I got the second section pretty much done this week on the 9W project.
Still need the 3rd section. .040'' rivet detail Fitting up the splice what a time consuming job this was trying to install all the 0-80 socket head screws ready to solder second splice 100' or 75'' scale boom |
#211
Wow Steve Looks awsome...So close to being done for the cabin fever and wish I could be there to see it in person..Im totaly impressed ...great work
#212
You will have to come next year with all your forestry equipment . IH steve and I talked about having a stripping diorama starting with cutting trees then scrape the topsoil off and start removing overburden down to a scale coal bed to load out I was saying around here in the past, the coal co's just push all the trees into the pit and cover them up with a D11
#213
that's just crazy!!
#214
Looking great! hard to believe it has to get bigger yet.
Jeff |
#215
Fantastic work Steve, looking forward to see it finished. Is everything done inside, drums, brakes.....?
what´s the capacity on bucket? Dan |
#216
Steve great job looking forward to seeing it next week. Ed
#217
All that brass!!!! What a monster!! Hope to see it next week!
Lynn |
#218
Thanks again everybody.
Does anybody know of a source for lighting? I want some big spot lights on the boom. I was thinking of buying Mini Maglite reflectors and build my own using their Kypton bulbs. I found I site that has model boat spot lights. I may get one and see how it works. Last edited by 9W Monighan; 01-07-2011 at 03:28 PM. |
#219
On my model I will try using Plexi cut to size, drill a hole on rear and put a white LED.
The Plexi was bought as scrap at local dealer, LED´s are 5 for $4. Plexi comes in different sizes, sheets, rods, I use 1" sheet (part of) and cut with bandsaw. My LED´s are 3,2v 20mA, 2 connected togheter can be runned on reciver battery. The brass strip will be used as guards outside lamps (on CAT models). Dan |
#220
Well Steve have you got it all packaged up for York next week? I will see you there. Ed
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
