RCP’s Aluminum Gravel Boxes and Accessories Welded aluminum dump boxes and more |
In the pics above, where the small jam nut is, on the pintle eyelet, can you custom make one that would be 5 inches long, from that nut? I need a compensator for a PNW stylr logging truck I will be building this winter. I think.......................there I go thinking again...............IF I did math right (NOT good at math) 5 inches, in 1/14 scale should equal 9 feet of real life?
5" in 1/14 is 5.8 feet. 7.714" in 1/14 is 9 feet or 195mm http://www.axialracing.com/products/ax30518 so if the lunette ring uses m3 x.5 then 2 of these would work, and get a m3 setscrew to connect them for 196mm.
