Old 11-13-2017, 09:56 AM
JDH429's Avatar
JDH429 JDH429 is offline
Default Re: Deadwood Sand & Gravel
Originally Posted by jjackso5 View Post
Very nice setup in your own yard! We're in Michigan, southeastern, let us know if you are interested in getting together for truck fun. We are going to try to get together in the spring, not interfere with any shows, but just do some garden trucking around here. Let us know if you'd be interested.
Again, great looking site.
Happy Trucking,
Jim
Thank you, I could possibly be into that depending on the work schedule at that time
Originally Posted by skeeter View Post
Me likes it a lot. It looks so real. Looks almost like the screening set up that the topsoil company I worked for a few years ago had going on.
I had seen one similar to this years ago too when i was hauling material, kinda what i based this off of.
Originally Posted by Hobbitzt View Post
It looks absolutely fabulous, Let the fun begin!
Thank you
Originally Posted by TheBennyB View Post
Great looking site! Looks like you've got plenty of room to play and expand if you ever wanted to.
Thank you. Yes, i do have another section that ill work with next year. I kind of left it unfinished so i can haul the screened material over there once i get a dump truck running and some conveyors possibly.
Looking good Jason!
Is the steel engine cover you made from 1/4"?! Now how did you get it to 107lbs?! That's 27lbs heavier than mine.
Joe, thanks. The body is pretty heavy at 8 lbs, theres quite a bit of steel there and not including the counter weight which i had filled with lead and added another 10 lbs( Then theres the undercarriage metal parts i added too to dress up the sides of the tracks. Those pieces of steel where chunky as well. Weight was measured on an old analog scale, so give or take a few there..
Jason
Currently Active Users Viewing This Thread: 23 (0 members and 23 guests)
