Old 01-11-2018, 02:28 PM
Yard Toad Yard Toad is offline
Yard Toad is on a distinguished road
Default Re: RC4WD Dozer, modifications, upgrades, settings.
Thanks for the info, I think we are getting this figured out. I just tried this with my one and only mix on my Flysky i6s. I will share the values that I have used for others to try and see if they also have some success. 1st set EPA for my pump at 40% that is the max speed i want my pump to run, set master channel with (valve of choice), slave channel always(pump). neg. value -40% pos. value 40% and -50% offset.
With these values when the mix is off and my pump is on it runs at 40% (my max speed). When I turn on the mix it reduces the pump speed by 50%(offset) and the pump now runs at 20%. When I open the valve my pump speed is at 20% and as i continue to open the valve my pump speed continues to increase until i have reached full open and now my pump is at its max speed of 40%. I believe you would just repeat the process for every valve, as long as your radio has enough mixes available.
