Old 01-19-2018, 04:39 AM
doodlebug's Avatar
Default Re: Air compressor trouble video
Originally Posted by Rvjimd View Post
Here is a video (some of you have probably already seen this) of my old quincy air compressor. The unloader valve cycles but it can do this for a few minutes before it shuts down. It does NOT build up too much pressure. The diaphragm of the unloader looks fine, old but not cracked and seems like that part is actually working. Im starting to think it is the pressure switch but not sure and dont want to tear into it before i have a better idea of how or what might be the actual trouble.
https://youtu.be/xiPihdiys_g
Jim
Hi Jim, does that air line connect, to an electrical box? You may have sticking contacts? Or the air cylinder inside is sticking. You should have a power cord going into the pressure switch electrical box, then wires or cord, going to the motor. Clear as mud? Google 220 volt air compressor wiring. Hope this helps!
Cheers, Neil.
