Old 02-14-2018, 06:28 PM
Machfab Machfab is offline
Machfab is on a distinguished road
Default Re: Bucyrus Erie 40H Excavator 1:14
Looks HUGE!
What's your boom/stick weigh?
The boom/stick of the Vario are paired 5mm plate steel incased in GFR, they're heavy! (don't know weight) A combo of EPA & curve in radio settings, the movements of each are smooth with twin 18mm bores on the boom & 22mm on the stick @35Bar - 1.8L flow
I would guess about 8 lbs. I will test “as-is” and then reduce weight if needed. I don’t think hydraulic power will be a problem.
