No Neil, as little caulking as I do, the manual version will work just fine.
![]() Maybe when I retire in 6yrs Ed, this is an outdoor model... when it's nice outside in the summer I'm usually balls to the wall busy. Yes Marc, the other Joe got a nice shine on it. ![]() I let the joint sealer set for 36hrs, then tried to pull the grade loaded, the right two rears let go again ![]() ![]() So I took the axles from the cross dump, I already have the stub axles drilled & tapped for the hubs with roller clutches. Now the adt & pup runs up the grade like it were empty. ![]() ![]() ![]() ![]() ![]()
