Mechanical tech This is for the mechanical parts of a model. Gear reductions, Axles, Transmissions, General drive line |
If I remember the gear box internals correctly, the reason it's advised not to replace with ball bearings is that those bearings need to both slide and roll freely. Ball bearings are usually not very good at sliding. Glue prevents them from popping out of the plastic thing from the push/pull force.
I have a feeling I greased that instead of gluing in my current build. Thanks for the reminder to check. |
![]() Big John
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. YOU WANTED THE BEST AND YOU GOT THE BEST THE HOTTEST BAND IN THE WORLD...KISS!!!! |
I am building my first KH and just finished the trans. Installed bearings throughout just prior to reading this thread. I have 1 bearing not sliding well, and I agree with Wombii. I'm going to swap those 2 bearings for the Tamiya bronze bushings.
Currently Active Users Viewing This Thread: 13 (0 members and 13 guests) | |
