Old 05-27-2018, 08:34 PM
Default Re: 3D Printing Test
If you do another round of testing, how about some strange mixing B with D and E.
Make piece with I-beam type opening but thicker walls, print at 100 infill, wider aluminum insert with radiused corners (1/8" min), print second flat plate that lays over i-bead side of first, and solvent weld the printed parts together.
That's a killer test! Thank you for planning, setting up, carrying that out, and documenting! Wow.
