Old 03-09-2020, 02:35 PM
avel avel is offline
Default Re: LR634 loader with Premacon fittings.
I ordered new hydraulic cylinders and a valve block from Magom HRC. I took the leimbach cylinders and valve apart to measure for new Orings. In the process I nicked one of the piston rods pretty badly. I'll try to repair it and keep it for other projects. I turned the pressure down on the pump as well to the stock 15bar setting.
I ordered one of Magoms aluminum track links to see if it would work on the Carson LR634.
Youtube username iamaman27
