  #34
Old 12-21-2020, 08:45 AM
tessen's Avatar
tessen tessen is offline
tessen is on a distinguished road
Default Re: Liebherr R984 1:14
mounting the casting trees
and so they come out after the process
and superimposed to see how they look
They do not come out perfect, but they are repairable and can be used, but since I think that I will not have time to weld and prepare this cabin, I leave it in "stand by" and look for how to make another cabin, more quickly, for this faster is 3D printing -> FDM 3d printing
This is a so-called "special" PLA so that it acquires all its mechanical properties, it requires post-processing a heat treatment, you have to heat the material up to about 80º and leave it there for a couple of hours and then cool
too hot .. to start over again
the cabin
the door
sandpaper, paint and well .. it remains "apparent" is what I like least of the whole machine
And at this point I am, I still have to add details, less and less, of course, the driver is also ready, but that will be the last thing I teach, it will be the "icing on the cake"
and some test:
caterpillar load test:
https://youtu.be/Z-bA_rgCn94
brute force test:
https://youtu.be/Rbchu3ASgpU
https://youtu.be/8DVwKnUj0wg
and the first videos of the machine, (very clumsy operator, I know)
http://www.youtube.com/watch?v=LuKBsjKK0CU&t
http://www.youtube.com/watch?v=24i7c4hAa8U&t
http://www.youtube.com/watch?v=EJQvPJ-JAJc&t
some photos of the bucket (it is the largest that the machine mounts, 8m3)
And a small mod for the radio, I use a taranis 9EX and it has a 2Ah NiMh battery but as it had been on the shelf for several years, when I needed the battery it was almost dead, it could not hold anything, so Instead of buying another battery packs, I have put an 8-element battery holder in it and put some rechargeable batteries with a higher capacity of 2.5Ah and if necessary, I could put even alkaline batteries
and to end i leave a pair of videos showing how i mod my radio to add 4D joystick in the original /M9 R sticks
in the first video show how the original 4D joystick works and how to disassemble
https://www.youtube.com/watch?v=JK_1...nnel=tessenCNC
in the second (and third) video show how i install in the radio, and how to
https://www.youtube.com/watch?v=LGgX...nnel=tessenCNC
best regards!
