Old 11-22-2024, 02:27 AM
Default Re: 1/16 Scale FrankenDiff
The 1/4-20 bolts that go through the bottom die form the outside of the U-bolt legs. I just counter-sunk the end of the slot in the top die and that helps to form the inner radius of the U-bolt legs. I have to cut the threads first, there only a little over 5mm between the legs of the U-bolt. While I have no doubt that there are people out there who can make and harden their own custom M2 dies that would fit in that 5mm slot, I ain't among them.
I ordered some 2mm ID brass tubing to protect the M2 threads while bending the legs, I have no local source for something like that. What did we do before on-line ordering? Don't answer that, I'm old enough to remember what we did back in the the "Old" days.
I re-made the top-die for the U=bolt bending contraption, I milled it out of a piece of 1/4"x3/4" hot rolled flat stock I had laying around. In the process of milling the top die I've discovered how poorly I've got things organized in my shop, and how badly I've neglected my little lathes/mills, I've got a Unimat SL that I purchased in 1973 from my local Sears catalog store. (Hold up your hand if you actually remember what a catalog store was, or even a paper catalog for that matter.) I've been collecting tooling over the years, but not that much experience. About 5-10 years ago I had the chance to purchase a Sherline 4000 and a BUTT-LOAD of tooling from a gentleman who was down-sizing his shop, it's mostly been sitting in a box since then. That has all changed in the last couple of weeks, they are now getting the TLC and attention that they deserve.
Don
Currently Active Users Viewing This Thread: 164 (0 members and 164 guests)
