Old 02-20-2011, 07:49 PM
aseejr aseejr is offline
aseejr is on a distinguished road
Default Re: ESC to use?
Something to consider is: What type of braking feature you would like? One is 'drag brake' and the other is your regular 'brake'. As I understand it, an example of 'drag brake' is when your truck is moving and you let your throttle go to neutral, brake is immediately applied (in the Castle esc the amount of drag brake is programmable). And if your truck is on a slope it would hold there provided that the esc is programmed accordingly.
