Old 05-13-2011, 09:35 AM
Car5858's Avatar
Car5858 Car5858 is offline
Car5858 will become famous soon enoughCar5858 will become famous soon enough
Default Re: Oshkosh Het M1070, M1000
Originally Posted by doodlebug View Post
Hey Carl have you thought about casting them yourself? http://www.lindsaybks.com/dgjp/djgbk/char/index.html
Later, Neil#2 aka doodlebug.
Thanks Neil I will look into that.
Originally Posted by 9W Monighan View Post
That IS some nice hand work. I like it.
On your solid modeling; Is that done with Autocad or Solid Works? I hope I can do that kind of drawing someday.
Steve, I did solid the modeling with AutoCad 2009. First make an orthographic drawing of the part you want to model. Copy that drawing and start a new acad3d drawing, then paste the copied drawing into the new. This way you have all the elements in the proper view. Then you can use the extrude, press pull, subtract combine and 3d rotate commands to finish your shape.
You can get fancy by adding surface textures and rendering to get jpegs like I have posted.
Then use stlout on the command line to create an stl file for export to bobcad or othere gcode generator program that you have.
As for solidworks, I am not that proficent at it so far. (still Learning)
