Old 05-14-2011, 07:53 PM
Default Re: MACK Heavy hauler
You need a high alcohol content 90% or more. The highest I have found is 91% and Freddy uses 92%. The alcohol may not work on all Paints but so far it has worked well for me. I have tried the Easy Off oven cleaner twice and had no luck both times. Maybe he used a good auto paint with a lot of hardener so maybe if you sand it to break the surface the alcohol will be able to penetrate to the primer and lift the paint from underneath.
