Old 08-06-2011, 03:15 PM
D8R D8R is offline
Default Re: Americans in Sweden
Neil, thanks for suggestion. Have had more thoughts about doors and will proably have a " hidden door" made into the front wall.
Have worked a little with the trailer. Bogie was lift off trailer and all rust holes was re welded with new steel plates. Sandblasted and painted in my color, the dark green metallic (same color as the truck will be painted).
All tires was removed from rims and they was also sandblasted and painted white.
Bogie rewelded and painted. Not decided yet if hubs will be dark or lighter green metallic. Bogie still waiting for final layer when turned around.
Rims blasted and painted in new color, white of course! Waiting for new tires. Planned from beginning to change to tubeless tires but then I had to change wheels to. Those wheels are not available in Sweden so sticked to tube tires, old school
Will continue next week to paint borders of trailer to correct color (if weather permits).
Dan
