#41
I would remove the servos, and operate them without a load to compair the throw. You may not have both servos timed correctly and they may be fighting each other.
Just a thought |
#42
just a ? Reg , did you try fiddling with your end points on the Tx ? it sounds like end point adjustment , Yes/no ?
#43
WOW, very nice work.
Joe |
#44
I must have missed this thread and it looks like you can really work fast. You Tig weld very nicely. I have to mount cheaters inside my helmet now to see small welds. Can we see some close ups of the tracks and how you made the grousers?
#45
I stole Greg's(RCLogger) carpet rail idea for the track pads so I can't take any credit there, the only thing I did differently was weld nuts to the links instead of using K1 type chain. I've done a little more work to it in the last few days so when I take some more pictures I'll post them up. As far as my TIG skills... just when I think that I'm getting better someone lets a seagull into the shop
![]() Thanks Last edited by RCP57; 08-19-2011 at 11:28 AM. |
#46
A few more pics. You can see the tracks a little better here. Welded on my guarding at 5:30 this morning. Time to build the dash, seat and controls. I'm holding out on finishing the undercarriage and lifting rams because once it drives without losing a track I won't make time for the small details
#47
I'm posting a couple videos of the 955 in... well action I guess. It's the second time running it so the operator is a little rusty, at least the machine isn't.
#48
I have a question... when I push into or pick up something and stall the bucket servos the sabertooth goes into protection mode and the tracks won't move until I relieve the tension on whichever servos are stalling. Is there a way around that? When the tracks stop turning the only way you can relieve the bucket is by lifting the boom so it kinda sucks.
Thanks |
#49
Hey RCP57, how do you have your battery or battery's hooked up, do you have the reciever running off of a battery eliminator circuit? What kind of shape are your batteries in? Didn't Ben, Snowchaser have the same problem with his skidder? See post 122 on down in this link http://rctruckandconstruction.com/sh...hlight=skidder Don't know if I've helped any?
Great work so far! Try sitting behind or next to it for a while, when operating it. That's from operating 1:1 equipment, still have a hard time when the model's are facing me, LOL! Later, Neil#2 aka doodlebug. |
#50
Looks to me like it operates really nicely. Great work, yet another model I'd like to build in the near future.
I am going to guess you are drawing to much power from the servos and it's "resetting" your speed control. You will need higher voltage battery and/or an additional one to operate the servos, this may alleviate your problem, that would be my guess. Ben |
#51
If your using the BEC on the speed control , it will not put out the needed amps the high torque sevos need . get yourself an external BEC . OTOH , the kitten looks great .
#52
Thanks for the info. If I plug a 6v batteery into the reciever in the batt/bind plug, do you think this will solve it or do I have to buy something else? I tried posting a couple more videos last night but they didn't completly load so they'll be up soon. Nothing to exciting though, just me doing the same thing...lookin like a spode!http://youtu.be/KrTU9iBcgq0
#53
I have done that with a 4v battery without success. I did switch from a 12v to 14 and that made a difference along with a BEC.
Ben |
#54
#55
Thanks for the input! I have a 5 cell 6 volt 4200mah hump pack with the reciever plug on it so I will give it a try and see what happens. The cap may be a better solution to my problem though because the screwdrive takes up a lot of space and I don't think there is much room for another battery. I don't understand why the esc on the screwdrive still works when the sabertooth resets? Maybe it is more like a woman... sensitive?
Thanks again for all the help. Reg |
#56
Fantastic craftsmanship, once again. It looks beautiful in it's raw state. I am enjoying your progress very much!
Nathan |
#57
Wow, great work! No wonder you didn't buy my mill when you have the skills to do that by hand. Being able to tig weld (which I can't) really opens up some possibilities for assembly. Are you going to build something to go with it?
Richard |
#58
I already have my R18 to haul the dirt away so I have that covered but even "my better half" was asking me what was next just last night. I'm not sure though, I may build another fish boat... or an 850 KW logging truck... I probably should build something that makes money not costs it though. ![]() |
#59
So I have a problem... I visited the local hobby shop today (over an hour away
![]() Sorry for all the questions but I think you guys are more in tune with this than the local shop. Thanks Reg I need this thing to work properly for next weekend! |
#60
Plug the battery and the servos into the receiver it should be fine and it works that way. The bec will plug in and work the same way but you will be better off with a separate battery. The bec like Castle Creations say 10 amps but it will handle an instant amp draw of that but not a continuous and the continuous rating goes down the higher voltage you put into it. I had a similar issue with my 4WD cat tractor I was only trying to run one high torque 1/4 scale servo and Castle Creations bec would not do it but a good receiver battery would.
The CC BEC 10A Receiver Battery Eliminator by Castle Creations. FEATURES: Eliminates the need for a receiver and servo battery pack Draws higher voltage from the motor batteries and drops it to a voltage level suitable for the receiver and servos CC BEC receiver battery eliminator SPECS: Length: 1.2" (30mm) Width: .6" (15mm) Height: .4" (10mm) Weight: .4oz (11g) Input voltage: 5V to 25.2V (2S to 6S Li Po) Current output: 12 volts input = 7 amps* continuous, 10 amp peak; 24 volts input = 5 amps* continuous, 7 amp peak *Ratings are determined with a 5mph airflow on the BEC Selectable Output: 4.8 - 9.0V via the Castle Link Default voltage is 5.1V Travis
