Old 09-18-2011, 05:20 PM
DuelTruckDriver DuelTruckDriver is offline
DuelTruckDriver is on a distinguished road
Default Re: 55 Pete 281 DUEL W.I.P.
More pics of the tag axle installed it turned out really good Thanks again Travis for the housing
I did move the front axle foward and made some shims to raise the front end back up. When you move the axle foward it lowers the front end about 2-3mm.
Got the front grill sketched up, gonna be a good bit of work involved in making it also. Notice how much taller the old grills are compared to the more modern ones. One reason was that the front frame horns were angle cut so the grill pretty much all the way down to the bottom of frame channel.
>Marty<
"You play meat?"
