Old 11-22-2011, 11:25 AM
Southgate Southgate is offline
Southgate is on a distinguished road
Default Re: 1/25 6 Axle Lattice Crane
Nathan, for cutting styrene, you spin the cutter SLOW. You have to be able to see it turning, not a blur of speed. I use it to make duplicate strips. It's so easy to get it off when cutting, say a few 3/4 inch strips with an exacto. Seems they'll be off by a couple thou, which may ot may not mess you up. But when you can cut them to about .050 over then mill them to spec, they will be right on. I also used it to mill out all the window openings in the cabs, nice and STRAIGHT.
