Old 12-10-2011, 09:11 PM
crawler07 crawler07 is offline
crawler07 is on a distinguished road
Default Re: Pete 367 in brass
Great build Sir! I am also building a couple of brass trucks and when it came time to build the hood and roof I decided to build them from copper instead of brass. The main reason is due to how malleable it is over the brass It will form the corner with the use of a little heat. You can just build a wooden buck instead of foam so you can hammer and heat it over the wood..just another way to build...
