Hello from Malaysia
Hi everyone! My name is Azizul, and i've been visiting this webpage so often, as I'm a RC maniac too. Been reading a lot as to learn and understand all the tricks and lesson learnt from all of experts here. About myself, working as an Engineering in a SEMICON facility here, but really fall in love in RC, specially Construction equipments..EXCAVATOR. Not sure how to start and make post as to intro about my RC works, but i've create a BLOG as to keep all my pictures, happy viewing and comment there. http://my-rc-page.blogspot.com/ ------------------------------------------------------------------------- Re: Hello from Malaysia Welcome Azizul we are glad to have you here. I went and checked out your blog and those are some nice machines you are working on. Travis -------------------------------------------------------------------------- Re: Hello from Malaysia Your constr equip model construction shows great promise Azizul. Per your excavator: your track drives look weak for such a heavy model of 40kg. At the very least you should have bigger bevel gears for greater gear surface mesh, the track sprocket drive axle should be housed within a cubed dimension for support on two points and both bevel gears properly shimmed to prevent seperating from each other. And may I also recommend that you do not exceed 25bar to keep your hydraulic system intact. If you find your hyd power lacking, increase of your cylinder bore is much safer than higher pressure. ![]() For me to post one your pictures here, (using Windows PC) I merely right click on picture, click properties, copy url & paste here in this forum using the image code [img] your pic url [/img Quote my post to see to see the link code fully. Please feel free to start a thread of your const equip creations in this forum http://www.rctruckandconstruction.co...isplay.php?f=6 Lil Giants -------------------------------------------------------------------------- Re: Hello from Malaysia Welcome aboard! Neat project's. Doodlebug Last edited by izzzul; 01-08-2012 at 07:09 PM. |
Thanks everyone, glad that you accepted me to join this page..
Lil, I have the same fear, tested on the flat floor in the house shows no sign of sweat at all, see below: http://www.youtube.com/watch?v=Y6DSmQBOrdk But when we tested them on extreme surface, the gear is breaking apart, no problem to the motor, but gear is a total damage... at this point my excavator total weight is about 90% of full weight, see pic below: ![]() Per your advice, i should go with bigger and better strength bewel gears, had ordered a some for testing this week. we are using TRUCK PULLER, LRP 5A BEC As for hyd powerplant..if you notice, i'm using industrial hyd pump, attached to powerful brushless motor, spec for 100bar max!!, but tested to 17bar with no issues/leaking, using teflon seals, nilon pipes. My only prob is control valves, anyone has some advice how i can improve them? Prob is servo kindda stuck and slow respond/fluid speed, any better design that we can try..? will upload the valve pic later.. |
I don't know how to draw in CAD to clearly explain my thoughts. This is the site where I obtained my John Deere 850 excavator, which is about the same size as what you are building.
You could either use these pictures as a guidline to improve your own track drives or inquire from Vario if they have a track drive component kit to sell to you? http://www.vario-earthmovers.com/bau...70-teil-2.html http://www.vario-earthmovers.com/bau...70-teil-3.html http://www.vario-earthmovers.com/bau...70-teil-5.html The servo automated rotary valves they use in their models work excellent too. http://www.vario-earthmovers.com/bau...0-teil-10.html Though your pump may be capable of producing 100bar, other components may rupture causing very serious injury. What are the limits of the nylon hose you use? You do have a pressure relief valve built into the system, correct? Safety first! ![]()
welcome Izzzol your excavators look great . with a little beefing up of the drive you should have some fine working models
![]() ![]() Steve
chain bracket..i can source this locally, quite cheap stuff, not sure whether it sell elsewhere..looking for some old pictures to share here, later.. Azizul Last edited by izzzul; 01-09-2012 at 03:13 AM. |
Hi Joe,
I admire your dedication and work ethic here. Thx for giving a great advice regarding my own build KOMATSU Excavator.. If you notice, i'm making quite a big one, boom arm stretches a little over 1 meter...and it gonna be heavy. ![]() The track shoe looks akward (see pic below) as the chain links are pretty big in size, cannot find smaller ones..unlike yours below: ![]() Why i dont buy ready made excavator? 1) Dont have money that much.. 2) Dont like their support.. 3) I want to learn from scratch...build one on my own..like it.. 4) I wanna make it bigger in size and more powerful hopefully can beat Germans.. sigh...! As for hyd powerplant, tested WEDICO parts from GoldenTrucking but not satisfied (not realiable, leaking and inssuficent power..see pic: ![]() I'm using industrial parts now, hyd pump and control valve below: ![]() New control valve (industrial type too): ![]() Today we tested this newly receive control valve and at just below 10bar, we can lift the entire boom arm and can hold steady...it was tight and no leak....all safety precautions has been taken care off, so it's safe i think.. will grab video later this week and share with you and the rest...what do you think...10bar or 20bar is sufficient for my size excavator..? ![]() The new gears for the track will show up later this week, will test that one too..i like the German's one, like the one on your 850D model..will see if it work or i have to make similar mod... Hope you have time to read my story, thx.. Last edited by izzzul; 01-11-2012 at 05:42 AM. |
That is some nice serious work.
I really like this build. Our machines are similar in size and we're at about the same point in our builds. Like you I also don't have the money to buy a kit but to be honest if I had the money I would buy more shop machinery and scratch build it anyway.
Keep the pictures and info coming! Reg |
I wonder how's your project progress, love to see your superb touch on those Al sheet, very neat and perfectly details.. do you mind to share yours too? i'd like to see the final looks.. how about your hyd system doing? Azizul |
It's cheaper for me to buy than scratchbuild... I live in a rather remote area with no access to materials, machines, custom cnc, ect. Everything would have to be mail order. I do enough fixing, head scratching, macguyvering on farm machinery nearly everyday that I prefer my hobby to be a ready made assembly that I can sit down and enjoy at the flip of a switch.
![]() Per my JD850, it's 1.4m from pivot point to tip of bucket at its furtherest reach. Weighs about 39kg (86lbs). Hydraulic pressure set to 25bar with 20mm diameter cylinders. The valves you show in the above photo are made by Leimbach for wedico, the same hydraulic system as my smaller Stahl constr equip. http://www.leimbach-modellbau.de/start.html What you have there now for valves is humungous, way more flow than what you need. It'll probably take 1/4 scale servos to operate them, the type of servos used in sail boats. Anyways, on my way out the door right now, going on a short holiday for a week. Talk more later. ![]()
hiya,
thought I'd share this link should you not have found it. I use parts books for inspiration and so far it's help me alot to develop parts. hope it helps www.komatsupartsbook.com/ ![]() |
I wish there was something similar for liebherr as I am building one for someone (thread on here)
but I got the design for the slew joint from there so that I can power the tracks hydraulically. rams and pump are coming from Damitz the Hydraulic motors I am going to make my self along with the control valves. I love your build was wondering what scale you were building to as I am working on 1/14 to fit in with trucks and the reach is about the same. look forward to seeing more. |
track hyd?? wow, this is something that i was trying to figure out how...So we can get rid off motors gearing ..
my build is meant for 1:12 scale, the PC650 is among they extra big size excavator, so i notice that it's actually bigger if you compare the std series excavator..i'll make tip to tip measurement later.. our hyd system is ready, so does the new gears for the track system, and will snape video for hyd endurance test this sunday, will share some when ready.. Last edited by izzzul; 01-13-2012 at 05:38 AM. |
Amazing work you have done on this so far!! ,look forward to seeing more of this,keep the pics coming
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Very nice, just had a look at your blog and its impressive to see it lift, looks like your using a 1cc gear pump? have you worked out how to move your valve block with servos yet?
![]() Last edited by izzzul; 01-16-2012 at 08:47 AM. |
this is the video for the lift test of 7.8KG or 17lbs load ..using smaller rated cylinder (capped at 15bar) on our test/mock up unit..this is sufficient i think, moreover, i'm going for better cylinder (SMC Japan) which can max up to 30bar...to match with the pump which currently producing steady 25bar right now...
Linear servo will come later...anyone already tried this before? pls guide me.. http://www.youtube.com/watch?v=h_gCTdpeIPs |
Wow, what a beast of an excavator! It's huge, and looks like it could dig all the way to the other side of the world.
Nathan |
