Old 02-09-2012, 12:37 PM
modelman modelman is offline
Default Re: UH-OH!! Swing motor problems
Originally Posted by doodlebug View Post
Are the bushing's, bearing's sticking from the grease inside taking a set? Some time's the oil in the grease evaporate's and leave's a thick mess. Can you measure how much current the motor is drawing, to compare to the other's on your shovel?
Cheer's, Neil.
As I stated above the motors are totally enclosed so I cannot check the lube but the motors start and run smoothly and are only drawing .1-amps so I don't believe this is an issue. Thanks to everyone.
