Old 03-22-2012, 04:59 PM
TRUCKMAKER's Avatar
Default Re: evercoat poly-flex filler
I bought the Evercoat Poly-flex 411 and read this thread before I used it, followed Travis'
advice, 220 grit scuff, 91% rubbing alcohol let it set over night and then put the putty on it and it worked nice. As far as peeling and flaking, I used a scrap peice of styrene to mix on, since it was smooth the dried putty peeled right off. I started to get some peeling because the mix started to set as I was going around the top of the cab. When it kicks off it goes pretty fast. I just stopped, cleaned the flakey stuff off and made a new batch to finish with. Thanks for all the help out there!
