Old 05-31-2012, 12:33 PM
modelman modelman is offline
Default Re: My new Cat 769D Dump
cbazq271-thanks for posting the info-too bad the firgelli's will not lift the box. However,you can get lot's of power from a screw drive if it is designed properly and I think you have plenty of room. Look at my post on the 777D, page-10-post-#188 and see my screw drive which I only had-2"-travel to work with. It was tough to work out but it can be done. You will not need folding lifting arms if they are placed correctly. A screw drive is a lot cheaper than hyds. and takes up much less room but of course that is your decision. Post pictures of your progress. Good Luck
