#101
Can sure agree on that. I actually calculated and marked the length to cut before bending. The first cut was just a bit too long (and luckily not too short).
#102
If you think on the lines of the neutral axis of the piece your cut length will come out close plus the flat material on the ends . When you bend something, the outside area is stretching and the inside area is compressing. When we bend and cut an arc we calculate the circumference of the web were we can wrap a tape ruler around and cut to size.
#103
Yep, I meant the length of the neutral axis
#104
Here some "making of" pics. First the brackets for the blade tilt cylinders.
The original. Actually, I just realize I forgot to round of the outer corner ![]() Cutting at an angle saved some material. Getting the top surface of the pieces parallel with the top of the jaws (having made sure the latter are at a right angle to the spindle axis). Later, same procedure but new set-up for drilling. 1.2 mm drill. Tapping M1.4. Always quite scary tapping the smaller threads in stainless 1.4301 (SAE grade 304), since this material has a strong tendency to work hardening. But I need it for its weldability. To be continued. Thanks for looking. Stefan Last edited by Stefan; 11-06-2017 at 01:02 PM. Reason: Link repair |
#105
looking good. Wish I had a thimble full of the talent displayed in these projects.
#106
Some more circle making pics. To start with a "quick and dirty" jig for adapting the bracket base to the radius of the circle ring.
And another setup for rounding the bracket ends. The center of the bracket hole is offset by 0,5 mm from the center of the turning table. Each bracket was provisionally fixed with two welding spots to a circle arm. Here the brackets have already been hard soldered and the circle arms are being connected with a 16 mm rod. Thanks for looking. Stefan Last edited by Stefan; 11-06-2017 at 01:07 PM. Reason: Link repair |
#107
A lot to do 1 model, here´s 2 at the same time! guess you will have spare parts for rest of life, ha ha.
dan |
#108
Yeah, Dan, assuming the build itself doesn't take rest of life...
Sometimes I wonder whether making two was the wisest decision ![]() Stefan |
#109
#110
The tandem bearings are ready. There´s a split outer ring attaching to the tandem box, an inner ring attaching to the rear axle and a bronze ring there between, fixed relative to the inner ring. The bronze ring has the same dimensions as a certain "standard" 4-point contact, thin section bearing with a split inner ring. Unfortunately, however, the only supplier I know of couldn´t deliver
![]() To the left the two faces of the outer ring. At the end I decided to split the bronze ring and make a one-piece inner bearing ring. Finally, everything fits. Making of The bronze rings were made first, to allow for easy test fitting with the other rings. The main outer ring portions being parted off. Test fitting during grinding. The stub was barely long enough for machining the other outer ring portions. I hate making thin things. Either you have this rather insecure and hard to adjust grip or you have to make a jig. This threading apparatus is really an excellent tool. Thanks for looking. Stefan Last edited by Stefan; 11-06-2017 at 01:14 PM. Reason: Link repair |
#111
Once again, excellent job Stefan. I don't have any more words to praise your work
![]() About the threading apparatus for how small tap can adjust it ?
#112
Your skills are amazing ,a true artist.
#113
![]() ![]() As to your question: My device from Vertex (VTA12-JT6) officially takes M3 to M12, but I just test inserted an M2 (shaft dia. 2.9 mm) and an M2.5 (shaft dia. 2.7 mm [sic]) and that seems to work too (for the M2 only the threaded portion was visible). For the smaller taps the lower limit of the adjustable torque might be too high, but I still think it would work for M2 in aluminum. According to the user instruction there´s a smaller model (VTA7-JT6) for M2 to M8. Stefan |
#114
May I ask where did you by yours ?
#116
#117
Can imagine it served you well during the excavator track build
![]() I on the other hand haven´t spent much time in the workshop lately ![]() What looks like a shadow in the right uppermost (finished) insert is actually an O-ring (11/1 mm). Stefan Last edited by Stefan; 11-06-2017 at 01:16 PM. Reason: Link repair |
#118
This is definitely a build to watch I love the detail I must say all you guys that work with a lathe and milling machines are very talented
#119
Sorry "speedy8305" and everyone else, it has not been so much to watch lately, but I did manage to make some more parts for the cylinders.
Here the circle drive cylinder parts. Only the cylinder brackets are still missing. Of all cylinders I´d like to finish the circle drive cylinders first in order to be able to perform tests and find out whether the control valve can be made to scale (if at all ![]() Stefan Last edited by Stefan; 11-06-2017 at 01:19 PM. Reason: Link repair |
#120
Stefan, nice to see that you started building again, looking forward doing an inspection locally maybee in april!
Are all the "white" parts made in Delrin? /Dan |
Tags |
1:8, grader, volvo |
