Old 11-02-2012, 10:46 AM
Default Re: geared motor
It's all dependent on your model's wheel diameter is, the voltage you want to run, and what kind of scale speed you are after! It's really hard to just suggest the right motor, without knowing all these other factors. Usually something around 20-35 RPM at max voltage gives you a decent scale speed, with a 6" tall tire. Or about 1.6 actual miles per hour, on the high end. 16 scale miles per hour, on a 1/10 scale model. Or 22 scale miles per hour on a 1/14 scale model, which is fast for a loader. It's all in the math.
