Old 11-11-2012, 05:47 PM
scalelover's Avatar
Default Re: Wheelbase measurements
Sorry if my description was a bit unclear. When I was describing the axles I meant both rear axles --front tandem and rear tandem. I knew the front measurement was from center o the steering axle. But yes this does help very much, I just was not sure at which point I should measure in the rear. So knowing that its at the center point of the suspension I can finally start setting it up.
--Dan
