Old 11-25-2012, 06:03 AM
carp carp is offline
carp is on a distinguished road
Default Re: converting from fergilli rams to air . but no power
You dont know if you dont try, you could use them for small stuff, try filling them with water and piping 2 together so you push 1 rod down and it pushes the other up, then attach 1 to something you want to move then attach the other to a servo or actuator, only works well if you get no air in at all.
Old 11-25-2012, 07:53 AM
cosworth34677's Avatar
ya i was playing around with them. and kind of found that out. looks good for my next build. i hope they hold up hat way. i may switch to oil like 3in1 or brake fluid
