Body Shop Tech Body mods and tricks of the trade and painting tricks here. |
I have wired them into my Parking lights circuit, no relay required if you are using LEDS (Low curent Draw) so they can be run with the parkers. The other way is to wire them into the speed indicator lighting circuit, so they can be switched seperatly than the parkers, but the parkers will have to be turned on for this to work. Hope this helps.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Australian Heavy Haulage "Keep on Truckin" |
Well, further update, I have added more lights tonight (Side step and sleeper lights) and have ended up having to split them up between the head lights and aux light channels, to get enough voltage to run everything. Maybe the idea of a relay is closer than I thought.
Looks great in the end though!
cammo can you send me a pic up your setup if possible
