Body Shop Tech Body mods and tricks of the trade and painting tricks here. |
Ok i belive you are trying to acheive this?
![]() If so i used port J15 on the MFU took a MFU lead from the globe i wasnt using happend to be a brown and yellow one... I cut the stock wires about 6" from the plug and solderd new wires on i used brown to brown and a white with brown stripe to the yellow ( i use Cat-5/phone wire its small bendable and works great) the brown wire in this case is our possitive wire + and soldered that to the Poss of the first LED or the rounded side looking at the bottom of it (should have the longer post). take a seperate wire doesnt matter what color and solder it to the negative ( be sure to cut one long enough to run to next LED) like so ![]() Then take the neg from LED 1 and solder it to the Poss + of LED #2. Take another wire and solder it to the neg like so ![]() Now the neg lead from LED 2 ( i should mention the neg side of the LED is flat on that side when looking at the bottom) and solder it to the Poss to LED 3 ![]() Repeat soldering the neg from LED 3 to the Poss of LED 4 BUT this time the neg from LED 4 goes to your yellow wire from the MFU in this case being our white with brown stripe wire. ![]() If done correctly you will then have this ![]() ![]() Hope that was what you were looking for and it helped. If you run into issues just shoot me a PM and i can help walk you thru some more. ![]()
