Old 01-01-2013, 05:58 PM
cosworth34677's Avatar
Default Re: How to make hydraulic valve?
so what if you put some kind of "buffer" between the Aluminum? like a brass thin shim or washer? of even a brass gasket? the only reason i ask because again i only have the abillaty (<---spelled wrong) to cnc aluminum? the cnc router at work will only route softer metals only because of our bits. and the boss won't let me cut steel on it i asked before for parts for my real car.
