Old 01-12-2013, 03:58 PM
Default Re: Smoke generators #%}^+]!
Did you use that one from Aristocraft?
I had one of them running on 12v, worked pretty good for a long time.. my plumbing was too small (1/4), not alot of smoke, although just the right amount, looked really kool in 3rd gear with a light stream off the top of the stacks. The back pressure the small plumbing caused created a lot heat within the unit which eventually burned it out.
