Old 02-10-2013, 10:44 AM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Kaf343 is an unknown quantity at this point
Default Re: PMD 4:1 brand new split
Originally Posted by scalelover View Post
Kaf, I wasn't trying to say it was a badly designed part I was just wondering how he did the finished machining. With the angled pics I can see a lot better how it was done and it makes sense because you can see how it was machined around the bearing cap, and not straight into it.
As for repairing it, IMO I'd say it probably wouldn't hold up unless its welded. The force that's put on the bearing is prob enough that any type of epoxy or aluminum weld putty may hold up for a short period, but it would probably just rip apart again. If your really good at welding you could do that and it would be fine as long as its lined up accurately.but again being such a small piece that won't be an easy task to do.i don't really see any other way myself, maybe a more seasoned machinist would know better.
--Dan
Dan,
Thanks for the input. I appreciate it.
