Old 02-13-2013, 12:18 PM
tracksntreadslou's Avatar
Default Re: Logging & Construction Equipment
Thank you Aron ,Jason and Paul ..Paul the Belt was sourced at a recycling junk yard ..Not sure where it s original use was for ..I had a heavier belt with the rubber pockets that was too heavy so i cut the pockets or should i say kleats off and glued them on the belt ..5 different glues and this one seem to be holding ok ..I did rip one off testing this weekend tho..Hey Paul ..Im thinking the the belt on a treadmill may even work better if you can find one thats been junked
I have a few buggs to work out and some minor adjustments and we will see ..The bruders had to be drilled out at the end holes to tighten up the belt and speeds a touch fast but i can live with that ..I ran some gravel through and it worked ok
