Old 02-20-2013, 08:02 AM
Default Re: CAT 374D L
Originally Posted by elliot330 View Post
Nice work as always Ari.
I guess it's so powerful due to the size of the rams? Am I correct in thinking that the bigger the ID of the cyclinders the more powerful they are?
What's your thoughts on the Kampfer ventil/valves?
Yes you are right Elliot, larger diameter cylinders are more powerful.
On the down side they also need more capasity from the pump and also larger hydraulic lines.
My cylinders have 18 mm bore, so they are not that large.
I'm very pleased with the Kampfer valves so far
