Old 02-20-2013, 04:57 PM
Kaf343's Avatar
Kaf343 Kaf343 is offline
Kaf343 is an unknown quantity at this point
Default Re: Stahl 922 help
That's Liembach's esc, it always works in mix mode, can't turn it off for individual ch function like the choice you'd have with a Sabertooth.
I'd move from Aux 1 to Aux 3 so the knob will give proportional control for/rev. Then Aux 2 used for steering.
With the 3pos switch centered on Aux 2, it should drive straight, and up or down should steer lt/rt... is it doing that?
I was using some 9amp Banebot esc's for pump control, but Robotmarketplace no longer can get them. But this one from E-flite seems to be a suitable replacement and even has a lipo cut off should you choose to use one... although the lower voltage of 9 to 12.6 will slow down the hyd speed vs a 10 cell @13.4v fully charged.
http://www.robotmarketplace.com/products/0-EFLA105.html
Then setting up the mix on the radio is super simple & will extend batt run times greatly not having the pump run wide open all the time.
Joe, just tried switching the aux1 to aux3, and now with aux2 three position switch centered the left track moves slow in either direction when moving aux 3 knob. When aux2 switch is up or down both tracks move in either direction when turning aux3 knob.
I tried switching aux2 with aux3 as well and that's worse when switching aux2 one track goes forward and the other backward.
Sorry to bother you, but any thoughts?
