Old 03-02-2013, 06:26 PM
Default Re: Kenworth 850 Off Highway
Oh man, Reg, after seeing your axle in this mostly completed state, I think I'm just going to throw in the towl with my build! That looks awesome.
Sorry about the mill giving you problems. I guess if you have digital multi-meter, you need to see if you have in coming power first, and if you have some fuses, you need to check that they are good. Just pull the fuse and do a continuity check - meter set to ohms. Not to familiar with your mill. Does it have a speed controller? Maybe you just have a bad push button or switch?
In anycase get it going so you can continue with this incredible build!
