Old 03-29-2013, 01:27 PM
Default Re: Futaba gearbox ratchet
Ahh, I apologize for not reading your orignal post close enough. You want to add the rachet mechanism to the left and right stick movement, and for that, I am not sure it can be done. Perhaps Futaba will have the answer for you! Good luck.
On another note, I know your radio probably does not have a three position toggle switch, but that would be an ideal way to shift, and hold the gear selection. Many of the radios with 6 channels and up do have toggle switches. It might be worth upgrading your radio at some point in the future, if you can afford it! You can never have to many channels either.
