Old 04-02-2013, 06:14 PM
rockNmayhem's Avatar
Default Re: Converting a POT switch on a radio?
Originally Posted by pumptech View Post
Hey Tyler ,this may be of some help ,fixed a coulpe of atv winches with momentary rocker switches using this diagram ,pic to follow ,the wiring should be close to the same .
Good luck with it
I know how to wire in that switch like so, but my problem I'm running into that I cant understand is that a potentiometer uses 3 wires that are alread in the radio. How can I convert those to to the switch? I suppose just removing the red and black wire to use as power and ground and then leaving the yellow wire seperate?
I'm not sure how that would work.
Tyler
~Tyler~
RockSolidCustoms
