Old 10-12-2010, 12:06 AM
SonoranWraith's Avatar
It's a dry 115 degrees.
Default Re: Lipo info
Paul had a great post on this at old garden. It was a great guide. The simple answers to your questions are 1. Yes 2. Not required. Lipos require voltage cut off because over discharge is ***aging. Cutoff can be built in to an esc or run as a separate piece. Novak makes cutoff unit for $25 that you can use with your esc. 3. You will need a lipo specific charger but it will be able to charge nicd and nimh too.
