Old 05-16-2013, 12:59 AM
Default Re: Carson L634
Benchtop milling machine? Clamp the tracks on edge, vertically, and you could probably mill as many sections as your vise is wide. I wouldn't even worry about disassembling the links.
Any idea what a completed set of tracks weigh? I'm just wondering how much extra weight these would add to a LR634.
Old 05-16-2013, 07:50 AM
doodlebug's Avatar
Yah, I like that idea too!!!!
Cheers, Neil.
Old 05-16-2013, 07:06 PM
Mitch Mitch is offline
Mitch is on a distinguished road
Mockup complete! Took your advice and milled the tracks. Came out fine. Also, the metal track application requires a change of bottom rollers (Top rollers are good). I made some extras for my "Wide Track" dozer ( exactly 12). They are about 2mm smaller, but work none the less. I also added a bottom plate for additional weight. Havn't got a scale, but I'm guessing it all adds up to around 4- 6 lbs. I plan to use fiberglass resin, and place No. 9 Birdshot into the Cab recesses, this should add a little more weight.
Mitch
Old 05-16-2013, 08:09 PM
Not far from Paint and Powder Coat !
Mitch
