That's a pretty cool heat exchanger. At first I was a little confused about the oil flow and coil tubes in parallel, but after following the path, I think it will work just fine. I'm used to seeing single coil tubes, so this is a bit different, but should reduce some flow resistance. Nice work. What diameter will the tubing be?
Nathan |
Currently Active Users Viewing This Thread: 77 (0 members and 77 guests) | |
