Go Back   RC Truck and Construction > RC Truck's Odds and Ends. > Die-Cast Conversions Tech.
Die-Cast Conversions Tech. The tricks of installing drive line and electrical components into die-cast models.
Old 09-10-2013, 04:35 PM
SmallHaul's Avatar
Default Re: He is at it again! 1:50 Dozer Conversion
Jim,
You could always use the control board out of a cheap but powerful servo to use as a speed controller with smooth forward to reverse action.
You would have to add resisters to the servo board to give you "center" just like converting one for continuous rotation.
i am sure the control board in this servo could feed up to 2 amps to a motor and i doubt you would even draw 2 amps.
http://www.hobbyking.com/hobbyking/s...Fc07OgodjU8Alg
Scott
"No load is too Small"
Currently Active Users Viewing This Thread: 11 (0 members and 11 guests)
