Die-Cast Conversions Tech. The tricks of installing drive line and electrical components into die-cast models. |
#81
SP,
You do realize I changed horses mid-stream? My current dozer is not the first one in this thread. I started out on a 1:50 and sort of gave up on that due to no room to hide the RX, battery, or install a blade lift servo. The one I'm working on now is 1:16. If I could change the title of the thread I would, I don't like to mislead anyone. I should've started a new thread when I bought the new, bigger dozer. ![]() Jim |
#82
I have more appreciation for you guys scratch building anything, after working on these track for two days! Holy crap there are a lot of pieces there!
![]() Got the new 1000:1 motors and tried one! If it doesn't try to kill itself or the dozer it should be great. Jim |
#83
Got the tracks refit with steel pins. And, put the 1000:1 gear motors on it.
I think is is just a bit slow now, not much but a bit, especially in reverse? I already took teeth off of one gear in the left side drive motor, so I'm going to find a way to run a bit bigger motor, faster and use a bigger spur gear to maintain the wheel speed close to the current video. http://youtu.be/RRdcbilOqL0 Good thing it is fun to try stuff, make it go, break, and repeat! ![]() Jim |
#84
Jim-I am glad to see that you realize how much work goes into a scratch build.
#85
I'm not sure if it is the screw up his back side, or that I keep putting his hair in the dirt, but he has threatened that he is going to quit!
![]() ![]() Jim |
#86
Looking good Jim! How's the operator? You two work things out lol.
#87
Hi Jim, New to the hobby. What is the name or contact info for the shop where you purchased the 1/16 metal die cast dozer you are using as the base of this conversion????
#88
Curly ,
I got two of them and the had more and pretty sure they ship stuff. It is Iowa die cast. They have a web site. Jim |
