  #39
Old 11-27-2013, 11:12 PM
tracksntreadslou's Avatar
Default Re: 140H Grader
Hey thanks Rob ..I took most of your advice .I did machine out the center hole and two outer to hold things true .then hand drilled the remaining holes ..It turned out pretty close but the far outside hole didnt work out very close so i may draw it out again and modify it later ..Quite a bit of geometry to that peice ..The whole mold table in fact..Hey thanks for that link ..I do have a few cycliners that will work kicking around and will use them for now ..Thanks again
