Old 12-13-2013, 01:48 AM
dabears's Avatar
dabears dabears is offline
Default Re: A little globe build
Undo the 4 nuts on each side holding the U bolts. slide axle forward in front of the rivet on the springs. then tighten nuts down,
Side note you may have to modify your cab and re cut the wheel arches, and you will have to re adjust your servo linkage...
Its a little bit of work but if your making mods it would put the fronts where they should be for a COE..
