Old 10-29-2012, 01:06 PM
Default Re: CAT 374D L
Everything is looking like it's coming together nicely. As far as the track width; It would depend on what the machine is going to be working on. Narrow tracks shorter frames for hard rock where no flotation is needed.
Old 10-29-2012, 01:13 PM
I Know the 385 ( which I'm building (2)) are 900mm (36")and 750mm (30") I'm making my shoes @ 64.25mm x about 19-20 mm .75" . I read somewhere that the 390 is just a renumbered 385 with a few added HP , etc
Old 11-10-2012, 08:31 AM
I started to make the cylinders
Old 10-28-2012, 06:33 PM
plow jockey's Avatar
Outstanding job!!
Old 11-10-2012, 08:56 AM
That looks very nice!
I would go for a little narrower track pads, other then that its a piece of art!
Old 11-10-2012, 09:25 AM
I've come to that conclusion too, I will make them slightly narrower
Old 11-10-2012, 11:32 AM
Yea, to bad you have to go thru all those pads again! Will be worth it though i think!
Old 11-10-2012, 11:48 AM
This machine is freakin awesome very very good skill you have I work on These machines and watching this build is great
Old 11-10-2012, 03:15 PM
kerst's Avatar
kerst kerst is offline
Looks beautiful!
Kerst
Old 11-10-2012, 09:16 PM
Beautiful job of the cyls Ari. Is that stainless steel for the pushrod?
Old 11-11-2012, 04:10 AM
Yep, it's 1.4305 grade stainless.
Old 11-17-2012, 05:30 AM
Got the rest of the cylinders done
Old 11-18-2012, 06:16 AM
D8R D8R is offline
Ari, nice looking cylinders. Du you solder the ends or are they glued to the tubing?
What pressure will you use in the system?
Dan
Old 11-18-2012, 09:21 AM
Dan
The pressure will probably be 20 bar or more, depending when my cylinders start to leak
Cylinders will be silver brazed, here's one that's been brazed:
Old 11-18-2012, 09:27 AM
mog mog is offline
wow you just keep out doing your self. what will hold the stick cylinder on a snap ring on the out side? are the bolts for the hose adapters end real or just on there and brazed on? thanks for showing us your work.
Old 11-19-2012, 11:04 AM
The stick cylinder and all the others will be attach with flanged pins that are bolted to stick.
Those M1.2 bolts are just for decoration, those hose adapters are brazed.
Old 11-18-2012, 06:06 PM
So what's the bore of the cyls and what size (ID) plumbing do you intend to use?
Old 11-19-2012, 11:07 AM
Cylinder bore is 18 mm and hose ID is 3 mm.
Old 11-24-2012, 09:37 AM
Made some plumbing today
Old 11-24-2012, 09:41 AM
Madda Madda is offline
Very neat!
What do you use for brazing?
