Where are they now? Any idea PFB? Travis figured out the servonaut on his and now I've got the sound like I wanted it. Awesome.
Ben
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 |
Don't think there's any shows. Must be a vacation.
I recieved one response back from ScaleART pretty much saying "our stuff doesn't have problems, sorry about your luck."
I hope to hear back a little more. I went and found some servos that will fit. I noticed the valve body had a sticky spot to it, so I rotated the valve around to an easily moved position. All is working with the hydros now. Fingers are crossed! Next step is to contact Brixil electronics to figure out the operation of their pump control unit. Ben
An updated....While I was taking in to get serviced.
![]() and another before the operation started. lol ![]()
You are an inspiration to many To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , you will not be forgotten. R.I.P. FGD Work Hard, Play Hard! Never Forget- 343 Last edited by Snochaser; 08-25-2012 at 10:09 AM. |
Ben,
It does look good... Which hoses did you blow? From the pump to the valve block or one of the lines to the rams? Just curious. On the servos, as previously suggested also check the end points. On my excavator I check them every now and then (every couple of months) just to ensure they aren't hitting the stops and damaging the valves or themselves. It will be interesting to hear how you go with Brixl stuff. Cheers, AP |
The first one was a bucket cylinder near the pump reservoir. The second one was right at the valve body.
I have looked over and moved done hoses around. The valves seem to operate easy by hand, the servos are at 100% on the radio now and don't appear to be over rotating. I ended up finding some Futaba servos that work. I'm going to put everything back together today and see if anything changes.
Have you had to adjust the hyd press at all from factory? Does the loader arms lift as you push into the pile. What voltage are you running?
No I haven't adjusted the pressure at all. I haven't notiiced any lift when running it.
Ben
What I meant was will the loader arms lift the bucket as you push hard into the pile? And what voltage are you currently running? 3s?
Oh, sorry. Yes it will lift as I push, it's pretty darn strong. 12v
That is probably the coolest model I have ever seen. Does ScaleArt offer a ripper for the rear?
That would be really nice! Last edited by Claus; 09-19-2012 at 04:18 AM. |
Claus here is a link to a new loader that a member posted here that has the riper on it. Scale Art did a nice job on the whole model, they are a work of art.
Link click here. Travis
AKA "00" Biddle RIP FreddyGearDrive 2-12-59/12-19-11 |
Just an update:
I think I've worked the bugs out. Did some additional cleaning up of the electronics, painted the cab. ScaleArt was great with all of my issues with it, helped me with everything, even replaced 2-servos for me. Haven't had any problems even digging in the dirt outdoors. Ben
congrats on getting the bugs worked out ,I know it must have been frustrating having such a nice model and not get to use it. But now you can get to work
Cool! What was it so others can learn from your mistakes?
now a video to seal the deal.
So now begins my new equipment build. A CAT 825H soil compactor
![]() This is as close to my eyeball scale of 1:14 ![]() I laid out my pieces on 16g brass then started cutting ![]() ![]() ![]() ![]() ![]() Stated soldering ![]() ![]() ![]() ![]() ![]() Installed a RC4WD R2 2 speed trans and LRP truck puller 3 motor, I'm using AFV planetary axles (stainless wire is for locking) ![]() ![]() body work is styrene ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I will be installing full hydro's (steering and blade)
Ben, this is very cool. Can't wait to see it one together.
Nice! I like those axles....
How long have you been working on this one Ben? Whats the plan for wheels? |
"Whats the plan for wheels?"
UH OH the CATs outta the bag now ![]() ![]()
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
